I have a customer with a F1 fault showing on her ISE10.
According to the manual this is an overfill. The machine is about a 3 weeks old. Is there anything stupid the customer could have done to cause this or am I going to have to go out.
Went to this today and the display was blank and water more than halfway up the door.
Tried to drain but just got a buzzing noise. Drained through syphon hose and removed kirby grip from pump impellor.
On quizzing the customer found out the machine had not finished previous cycle so she attempted to start it again and it filled then came up with F1 which is correct as it had overfilled. But why did it attempt to fill again when it was already full?
Anyway it is all working now, so in future if you get F1 fault check the pump.
