ISE10 – Noisy Drain Pump
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE10 – Noisy Drain Pump
  • #93626
    drummonkey
    Hi all,
    Sorry to trouble you all, I’ve not long dragged my ISE10 out of storage, and as a result I’ve been doing a few service washes to clean it through and check all is well. No clothes as yet just empty service washes.
    Everything seems to be fine, except the drain pump sounds really noisy and I don’t recall it being that noisy before. I checked the filter and that’s fine, nothing around the impeller or anything jammed in there. Given that it’s been a while, does anyone know if the pump is indeed that noisy or if it may be a problem with it at all? All I know is that while it was stored, my father in law (who is getting on, and not the strongest nor tallest fella, tried dragging around where it was stored by putting wheels underneath it. Could he have damaged anything? Or is it all pretty inaccessible from underneath.
    Cheers for any help.
    Al
    #455040
    Re: ISE10 – Noisy Drain Pump
    It would be unlikely for him to have damaged the pump from the outside. The machine does have quite a powerful pump and TBH is was never the quietest of pumps.
    Standing unused for some time won’t have helped and it may improve more with use.
    #455041
    drummonkey
    Cheers, that’s a relief. I’ll keep an eye on it.
