Ise10 problem
  • #92301
    Tim Pickard
    Hi I have an ise10 which will run through all programs but stops when it reaches the spin cycle any help would be great thanks
    #450872
    Re: Ise10 problem
    Full model number?
    Have you checked the pump filter, are you getting any error codes?
    #450873
    Tim Pickard
    Re: Ise10 problem
    Pump filter ok no fault codes ,it’s an intermittent fault .i have 2 main circuit boards and same fault accures when they are swapped
    #450874
    Tim Pickard
    Re: Ise10 problem
    The model number of the washing machine is ISE 10 1607W.
    Serial number104310944559. Type WM 70.1
    I have also used a washing machine cleaning liquid to make sure all the pipes are ok.
    No matter which program I choose it will have a blip when it comes to the spin, it doesn’t have to be the last spin it can be an intermediate one then the machine is stuck. The only way to change or move the program is to turn it off then on again. Let it drain then open the door
    #450875
    Re: Ise10 problem
    It may well be the pump has now failed and will judder when trying to pump out.
    Bryan
    #450876
    Tim Pickard
    Re: Ise10 problem
    Pump is fine it seams to be an electronic fault but could it be a problem with the controls or main board
    #450877
    Re: Ise10 problem
    The symptoms do indicate that the pump is worn out. Works one minute, judders the next. 😉
    #450878
    Re: Ise10 problem
    My first point of call would be the pump. But if you want the other parts then I have them in stock. On a non returnable basis though.
    Bryan
