My ISE 10 (1606W) bought in 2008 is now on its 5th thermistor. These keep failing at increasingly frequent intervals. Symptom is that the water never gets heated, but all else is OK. No fault code.
The thermistors seem to be getting wet (there is water on the end of the plastic bracket when removed). Although they look well sealed, I’m guessing water does eventually penetrate – but I can’t see anywhere the water could be coming from. Any ideas as to what might be leaking to get water to the thermistor?
cheers
Peter
