ise5 (2) E09?
  • #53970
    deltra
    fault guide says out of voltage? does this mean pcb is duff? or am i missing something 😕
    #317899
    Re: ise5 (2) E09?
    I had this on one once, must have been the household supply that had spiked or something. I didn’t see it on my visit and its worked fine ever since.
    #317900
    deltra
    Re: ise5 (2) E09?
    this one keeps coming up with this code,presume that board has blown. customer says that the fuse in house had blown.wonder what caused fuse to go 😕 hopefully is was a spike.
    #317901
    Re: ise5 (2) E09?
    Sounds like the inverter board or the wiring adrift . 😥
    #317902
    bazza500
    Re: ise5 (2) E09?
    I’ve had 2 dry joints on inverter boards and I’m fairly sure it was throwing up F09.
    #317903
    deltra
    Re: ise5 (2) E09?
    whats an inverter board ❓
    #317904
    Re: ise5 (2) E09?
    Its the main board in the base.
    Inverter
    #317905
    deltra
    Re: ise5 (2) E09?
    went to this machine today,replaced inverter board (burn marks), also replaced facia pcb(tracks blown off) everything now ok 😀 possible power surge caused this fault ❗
