I’ve had two of these now! I thought the first one might of been a freak occurance. But nope, women washing twice/three times a day, have worn down the brushes in two seperate ISE5’s after 18ish months of washing 😕
The bad bit, is that the machine dies when the brushes go OC. Put it on spin, you hear the pump for a few seconds, then as soon as the motor should come in the machine stop (with the lights still lit). I’m persuming it then goes into fault mode if you wait around long enough; personally, I aint got that much time to find out 😉
The good bit is, they’re a doddle to change 😀 and it can be easily done without removing the motor. The motor cover gets in the way a little, but aint so bad.
Anyhoo, now I’ve done two, I was wondering if anyone else had done any? Especially Iadom with his entire army of ISE5’s out there?
