ISE5 Error 08 ‘Motor Error Detected’
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE5 Error 08 ‘Motor Error Detected’
  • #103085
    thekitehunter
    Hi, The machine starts its spin cycle, turning the drum a little then stops with this error code. Can anyone point me in the right direction to fix this? I’m thinking that it can’t detect that the motor is turning.
    #491738
    well you could check that
    at the back of all washer motors is a little magnet that revolves in a coil known as the tacho
    you can get a multi meter and check the tacho coil for continuity and check the magnet is revolving with the armature and not broken
    if ok you can check wiring from the tacho back to the board to make sure the signal is getting there
    Three totally different ISE 5 machines made by Beko, Vestel and Amica. The Beko and Amica had brush gear motors whilst the Vestel used a 3 phase motor. What is the model number on the facia? The Beko and Amica did occasionally have tacho wiring related problems. Worth checking the motor brushes if it is either of those two. I’m guessing it will be either Vestel or Amica as the Beko did not have a digital display.
    #491740
    JosephBowen
    You are right.
    #491741
    RachelInouye
    Blocked
    iadom wrote:Three totally different ISE 5 machines made by Beko, Vestel and Amica. The Beko and Amica had brush gear motors whilst the Vestel used a 3 phase motor. What is the model number on the facia? The Beko and Amica did occasionally have tacho wiring related problems. Worth checking the motor brushes if it is either of those two. I’m guessing it will be either Vestel or Amica as the Beko did not have a digital display.
    You are right, I checked it. Thank you for making it easy.
