ISE5 mk2 technical info Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › ISE5 mk2 technical info This topic has 2 replies, 2 voices, and was last updated 17 years, 7 months ago by timdowning. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts September 10, 2008 at 5:16 pm #39380 timdowningParticipant Am I correct?? The pump and only the pump will run if the door is open and a cycle is started. The machine will then abort to E01. While the pump is running the module is carrying out a diagnostic check. Why I ask is a customer has just phoned in a bit of a panic that her son has just started the machine with the door open. September 10, 2008 at 7:27 pm #262283 Penguin45Participant Re: ISE5 mk2 technical info You’ve got approx 20 seconds before the door locks. I use it as a selling point: “Get that red sock out of the whites before it starts.” If the time is exceeded, just shut the door and it will start. Chris. September 10, 2008 at 7:38 pm #262284 timdowningParticipant Re: ISE5 mk2 technical info Cheers Chris. I take that as a yes then. 😉 How many selling points do you need???? Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
