ISE5 Vestel
  • #58087
    timdowning
    This is a new fault to me;
    Programme times are correct and all programmes can be selected but as soon as the start is pressed the display goes to 1 minute or 10 minutes.
    The customer says the cycle runs as normal and displays END at the end.
    I asked her if she could live with it, worth a shot, but she says she likes to know how long the cycle has left to go. Fair enough I suppose.
    I assume the fascia board is at fault?
    Ta.
    #333339
    I can’t be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure Tim but I think that this has been seen on a couple of machines and I cannot recall what the cure was.
    I’m also not in the office until tomorrow so I can’t check if there’s a reset on that one that may cure it. If there is it should be on the technical info that I hope you have.
