ISIS flashing lights
  • #76960
    johnjordan
    Isis 1205 the first two lights from the left of the control panel are flashing. The flashes are very rapid and there is no pause in between, meaning it is not a sequence of flashes.
    Any ideas please?
    Thank you.
    #400262
    johnjordan
    Re: ISIS flashing lights
    I should mention that I have cleaned the filter, checked the pump, checked the belt, cleaned out the hoses and checked the motor brushes. When the machine is first switched on the first light stays lit for a minute or two then a click is heard followed quickly by another click from the control knob then the lights start flashing.
    I have also left the machine switched off overnight to see if it would reset itself.
    #400263
    Hi John,
    Unless one of the guys happens to have some info on it…
    http://www.ukwhitegoods.co.uk/help/abou … chine.html
    There is the grave possibility that there is none.
    It is almost certainly an error code and, it’s almost certainly a Vestel machine but what it means, given the lack of information available, is anyone’s guess.
    I would suspect the door lock or water valve as the machine will, like almost all, run through a pre-flight check and try to detect components before it starts but other than that I can’t be much help to you.
    Jackal
    First two lights are Err1 which is a door lock fault or in rare instances the PCB
    Jackal
    #400265
    johnjordan
    Brilliant. I noticed that the door could still be opened even when I switched the machine on. I tried slamming the door as hard as possible then I took the top off the machine and wiggled the lock about. The machine started!!!
    Thankyou, thank you, thank you.
