i’ve looked, but cant find any fault codes for this d/washer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries i’ve looked, but cant find any fault codes for this d/washer
  • #37375
    TELL
    its a diplomat b/in d/washer. model ADP8520, s/no. FA56Q0466.
    all it does after setting a prog, and starting m/c, it beeps and the 1st four lights on the prog select panel flashes.
    their is 7 progs lights on this m/c, and the last three are out. i have looked through the f/codes list, and there is nothing there to indicate this m/c, and faults. can anybody help.
    “O” “O” “O” “O” / O O O
    heavy soil pots& normal glasses economy rinse plate warming
    pots, pans pans out out out
    lights and prog control panel as above.
    TELL..
    #254614
    Re: i’ve looked, but cant find any fault codes for this d/wa
    Welcome to the world of Haier! This is the fancy stainless steel jobby. long and short of it is flooded base. Drain off the water (plastic access panels behind bottom of door) and maybe you will see where it as come from, most likey not. recall in a few months. Maybe want to let the circ pump windings dry out before trying.
    #254615
    TELL
    Thanks.
    TELL..
