Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › IW810AU pump buzzing
- This topic has 8 replies, 3 voices, and was last updated 14 years, 9 months ago by
JamoAus.
July 6, 2011 at 4:35 am #63776
JamoAus
ParticipantHey guys, I’m Glenn from australia, nice to meet ya =)
Somebody on another forum recommended I try asking here..I have a Fisher and Paykel “intuitive eco” washing machine model IW810AU , and when switch is off, (power point on) drain pump is buzzing. It measures 36 Ohms and works on the bench when removed.
It doesn’t work on diagnostic mode using the fabric care button and no fault code comes up.Any ideas apart from replacing the motor controller?
Regards
GlennJuly 6, 2011 at 7:06 am #354876ratbag_359
ParticipantRe: IW810AU pump buzzing
So the machine can’t operate it?
And you can turn on the machine and will fill, wash,etc?
Just won’t drain?
If that is the case the triac in the motor controller has failed. or the control circuit for the triac has.July 7, 2011 at 5:06 am #354877JamoAus
Hi there,
Yes it does fill and wash, but not drain. During this drain motor continues to buzz. Occasionally the machine will cut out completely and needs a minute or two to reset.
Foud my house voltage to be 253v but when I connect it to my generator (241v) it works fine.
Regards
GlennJuly 7, 2011 at 6:24 am #354878ratbag_359
That is a interesting issue do live in town or out in the country?
July 7, 2011 at 10:24 am #354879JamoAus
Hi again,
It is a teaser. I live 16KM out of town, sort of semi rural. Neighbour has the same voltage @ 253 V.
Regards
GlennJuly 7, 2011 at 11:04 am #354880ratbag_359
well the voltage is within limits.
But the motor should still run.
The only thing apart from the machine having a quirky fault is the supply for the house been bad like a bad neutral.July 10, 2011 at 6:17 am #354881JamoAus
Hi there,
Dropped the voltage to 249 by plugging in a 800 watt heater and machine worked perfectly. Have to ring my supplier to find out why it is high. Thanks for your help.
Regards
GlennJuly 10, 2011 at 7:16 am #354882Allsorts
Re the Voltage.. proberbly just means low demand on the supply
July 10, 2011 at 9:17 am #354883ratbag_359
There maybe a bad neutral on the transformer feeding your house.
Or the power in your area may need conditioning.Allsorts wrote:Re the Voltage.. proberbly just means low demand on the supply
Agreed. Also bad neutral can cause it too. A few years ago in a rural area a lug for the neutral burned right off two houses ended up with 500volts coming in 😯
