Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › IWC71452 won’t power on
- This topic has 14 replies, 3 voices, and was last updated 4 years, 10 months ago by
keat63.
June 5, 2021 at 1:13 pm #99634
keat63
ParticipantThe Mrs says that the washing machine started making a clicking noise, sounded like the dial being rotated, but a bit louder.
Then switched off and won’t power back on.I’ve checked the fuse, socket etc.
I have the lid off and can’t smell anything burnt out.
But that’s as far as I’ve gone with it.I looked at the cost of a power board and this costs almost as much as a new machine, so other than that can anyone suggest anything simple I may have missed before I scrap it and buy another.
June 5, 2021 at 2:45 pm #477165electrofix
Moderatoralso forget the power board as it needs to be programmed once fitted so you would need software and programming gear
June 6, 2021 at 8:08 am #477166keat63
ParticipantI opened up the power board and found something odd at the base of a capacitor.
https://ibb.co/fCvn47V
https://ibb.co/PjL9BkCHas to be worth a try for 30p ???
June 6, 2021 at 1:07 pm #477167electrofix
Moderatori would say water has got at that and shorted it underneath
it probably blown the fusible resistor as well
June 6, 2021 at 4:53 pm #477168keat63
ParticipantJune 6, 2021 at 5:06 pm #477169keat63
ParticipantI found a russian site which mentions R044 as 10 ohm 2w.
removed it and found that it’s fused.
https://ibb.co/kmkvFN4June 6, 2021 at 5:31 pm #477170electrofix
Moderatorits also a fusible resistor so need same to replace
June 6, 2021 at 6:16 pm #477171keat63
Participantordered from RS components. Wish me luck
June 6, 2021 at 6:44 pm #477172electrofix
Moderatorcheck the board under the cap as it will have tracked and carbonised.
if it has really scrape it well and if poss drill a hole to break the circuit but beware of any other print in the area
June 6, 2021 at 7:56 pm #477173keat63
ParticipantI did that already and painted with nail varnish.
There appears to be have been a small amount of water ingress, as the opposite side of the board has lost the green varnish.
I’ll revarnish when the components are replaced.I’m intrugued as to how water got in there though to be honest.
Its at the bottom corner of the board, farthest away from any water source
It’s under a plastic cover.
It doesn’t make much sense.https://ibb.co/6RwtF7K
https://ibb.co/F5mYsK2I’ve drilled a few holes in the plastic cover incase it happens again.
What is intruiging is the Russian site I mentioned earlier has damage in the same area.
https://teron.online/index.php?showtopic=2371572June 6, 2021 at 8:26 pm #477174electrofix
Moderatorif there is nothing on the other side of that track drill a hole in the board to make sure it cant do it again. There is over 300v DC on that cap so it will track on any weakness
also dont put the cap so its touching the board, leave a small gapDave
June 8, 2021 at 6:11 pm #477175keat63
ParticipantWer’e back in action, up and running, already performed a full load.
My tests would indicate that the capcitor was working, but for the small costs involved it wasn’t worth messing about with.
I’m 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} confident that the ‘No Power’ was down to the blown fuseable resistor – R044
Thanks Dave, I don’t think I would have found that if it wasn’t for your intervention.
June 16, 2021 at 8:21 am #477176keat63
ParticipantStill holding up a week later.
July 16, 2021 at 7:23 pm #477177keat63
ParticipantThe fault re-ocurred today.
I took the board out and found dampness in the same area, with parts of the PCB tracks now burnt out.
I’ve no idea how water is getting where it is, and it’s not a huge amount either as there are no traces inside the body of the machine or on the floor, but the few drops there are is enough to kill it.
I can’t even figure out where it might be coming from, let alone how its getting in to that part of the mainboard.So today sadly it’s been put out to pasture for the skip fairys, and a new machine purchased.
July 29, 2021 at 4:09 pm #477178Gokhk
ParticipantSad when bad design causes something to go to the skip i would have conformal coated it but hindsight is a wonderful thing plus thats a lot of power so who knows unlucky mate gutted for you , hope the new one is all good
