Re: IWDC 6105 Fault Codes
Dryer NTC short/open circuit.
– Check efficiency of contacts on connector J011 (commutator) or
J14 (three-phase) on PCB;
– Check NTC impedance value on wiring connectors J011
(commutator) or J14 (three-phase) between pin 1 and pin 2.
The impedance value at ambient temperature (20°C) must be
approximately 20 KOhm;
– If measurement is incorrect check NTC wiring;
– Check the same parameter directly on the NTC (20 KOhm);
– Renew NTC;
– Renew PCB.
Error codes are in the Known Error codes thread.
HERE
NB. Moved this thread to Trade Tech, why did you post on the public forum????
