iwdc6105
  • #87903
    robbo1973
    hi all got a pain in the ass machine,went originally and wouldnt lock found interlock shorting an dblown the pcb,received replacement from emw and made sure door locked and filled and left it running.got a call from the letting agents as there chinese students saying now not draining so went back and it fills and tumbles fine on wash but when you set to drain it starts to drain fine you hear the relay click to turn the motor and it faults bottom 4 lights upwards dryer relay faulty,ive spoken to emw and they are adamant that its not the pcb but wasnt doing previous.
    any thoughts?
    #436359
    Re: iwdc6105
    have you checked dryer element for failure ?
    Re: iwdc6105
    Or the dryer side ntc, causes all sorts of weird faults.
    #436361
    robbo1973
    Re: iwdc6105
    hi yeah heater is checking ok and also the ntc is not open or short circuit and is moving when warmed up.i would normally try one in but didnt have one on me.its strange that it didnt do it before the pcb was fit.
