I have a 2 years old Indesit IWDC65125 washer dryer on test. The machine came in with all lights flashing, when switched on it started filling and draining.
Checked the drain hose, checked the sump and pump all clear. Checked the pressure switch, ok.
Disconnected the dryer element and the machine was working normally.
Tested with a dryer unit from another machine, it started working but all the lights started flashing again.
Is it most likely the board?
