Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Jackson Dishwasher 27904
- This topic has 11 replies, 4 voices, and was last updated 18 years, 4 months ago by
Phidom.
November 15, 2007 at 8:53 am #32213
ParticipantI went to look at this machine about 2 months ago but the part I ordered was on special order so it did not arrive until this week. The door wont close and I found there was a broken spring. There is a 3 sided sheet metal part which pivots about it’s bottom edge. When you press in the door handle that piece moves inward, opening the door and releasing the microswitch button. I didn’t see how it was fitted but the broken spring must pull the 3 sided metal piece outward to shut the door. The part I ordered was 1840378, door latch mechanism. I didn’t know what parts would come with this but it does not include the spring I need or the metal part or it’s pivot pin. I fitted all the parts that came with the kit except for an item they call an omega spring. I’m sure the broken spring was an ordinary wire type spring but I’m wondering if this omega spring is a substitute for the broken one. Trouble is, I can’t figure out how to fit it. 😕
November 15, 2007 at 9:18 am #234082Martin
ParticipantRe: Jackson Dishwasher 27904
Looking on Partfinder there are two springs, a return spring (1804285) and a Latch Spring (part OBSOLETE) 🙁 The latch spring looks like a very conventional coiled spring with a hook on each end. Apart from that I have never come across one of these machines…sorry. 🙁
November 18, 2007 at 1:53 pm #234083Phidom
Thanks Martin. I went back and tried fitting a spring from a washer front door seal wire but it’s too heavy. The door now shuts and the machine will run but it’s too hard to open the door. Usually you can see where there are holes for the spring hooks but not on this so it’s all very frustrating I will have to try a lighter spring.
It’s so annoying that they list a kit which you would expect to contain the parts needed but does not and then they discontinue the parts not in the kit. If they had just made all the parts obsolete I would not have attempted the repair. Now I’ve spent so long on the job that I really need to get it right to justify the size of bill. 🙁November 18, 2007 at 2:06 pm #234084Penguin45
It’s the old Thompson machine, which is now Brandt and is the same as one of the Diplomat/Hygena machines. Can’t work out which one with the info I’ve got, sorry 🙁 .
November 18, 2007 at 7:03 pm #234085goosegreen
have a look at: http://preview.tinyurl.com/272hoh Looks like it could be a set of springs you may be after.
Goose
November 18, 2007 at 7:10 pm #234086goosegreen
Sorry, That TinyUrl conversion didn’t work, Google Europart Loging and enter the Model Number. It shows a spring kit.
GooseNovember 18, 2007 at 7:11 pm #234087Penguin45
It does now……. 😀
November 18, 2007 at 7:17 pm #234088goosegreen
Ok, Peng, How did you do that 😆
GooseNovember 18, 2007 at 8:01 pm #234089Penguin45
I used my God-like Moderating powers to edit your post…… 😀
November 18, 2007 at 8:52 pm #234090goosegreen
Chris, Don’t understand what went wrong, Copied the long URL into TinyUrl and pasted it back to the post.
November 18, 2007 at 9:52 pm #234091Penguin45
You typed :
at:http……….
I just inserted the space.
C.
November 22, 2007 at 1:15 pm #234092Phidom
Thanks Goose 😀 I don’t have an account with Maddocks but hopefully I might be able to purchase the item.
