jackson dishwasher
Viewing 6 posts - 16 through 21 (of 21 total)
  • #227598
    fasetester
    Re: jackson dishwasher
    any one any ideas other than siphon lets here them please thanks fasetester.
    #227599
    Fase,
    If it’s constantly emptying, either the drain pump is running or it’s syphoning. There can’t be anything else….
    These old Credas were Thompson built French machines, before they became Brandt. There’s bu@@er all parts available, so your best course of action might be a sales job!
    fasetester
    thanks chris no the pump is not running so has to be siphoning. will have to get it out and raise the drain hose. where would you get appliances at the right price. see there is someone in the local paper selling machines at £100 must be graded or new £200. fasetester.
    #227601
    fasetester
    hi chris you were righ broken wire feeding the washer pump in the bottom of the door. the are a night mare to get out each leg has to be ajusted to get clearance. then a small nut to try and get the spanner onto and very little room to move. is there a tool for ajusting the legs fasetester. 🙂
    #227602
    I wish – 10mm nut moulding on the bottom of the leg? Trouble is, you can wind up the front ones, but you can’t access the back ones – which will collapse when you try and drag it forwards.
    Better have the blocks of wood handy if you do need to pull it out…..
    fasetester
    chris i did get the back ones up as well. with a lot of trouble as i could not get it out up over the stone tiles. as the plastic rests on the feet were catching there bound to be a better way some will have a screw at each side that you turn from the frount that winds up the legs fasetester 🙁
