Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › jackson dishwasher
- This topic has 20 replies, 4 voices, and was last updated 18 years, 6 months ago by
fasetester.
September 13, 2007 at 8:52 pm #30544
fasetester
Participanthi guys have to look at a intergrated jackson eco wash dishwasher mod 26120014 the problum is wont bring in any water but turns on heater the most likely cause a blocked pressure system or what else would cause this any pointers welcome and can you get at the workings from the frount with out takeing the dishwasher out thanks fasetester 🙂
September 14, 2007 at 6:08 am #227584bobokines
ParticipantRe: jackson dishwasher
Going back over twenty years now, so I might be mistaken…
Under the filter at about 11 o’clock position, there is a two inch high tube sticking up with a small hole through the top.
If I remember correctly, you need to suck any water out of that pipe. Best done with a drinking straw and a small syringe. You can also use a trigger spray head (from a bottle of kitchen cleaner etc) .
Good luck
Bob
September 14, 2007 at 12:47 pm #227585fasetester
thanks for the reply bobokines what do you mean by a trigger spray head. if that dosent work can you get at the pipe work from the front. as its an intergrated and could be a bugger to get out. would you be able to get a bottle brush into the pipe or is it a small pipe. would that be the most likely cause a blockage would trapped water in that pipe cause it not to fill . is there a pressure stop system on the valve and is there a i w m s type system on these dishwashers. and who made the jackson first one ive come across thanks. fasetester 🙂
September 14, 2007 at 5:04 pm #227586bobokines
Can’t really remember to be honest. It must be 20 years ago that I trained on these machines. I think the pipe that I am refering to is the top of the pressure chamber.
Bob
September 15, 2007 at 12:24 am #227587fasetester
hi martin or pen or old tog has any of you worked on the jackson dishwasher as the seem not to be popular thanks fasetester 🙂
September 15, 2007 at 2:28 pm #227588fasetester
went to see the jackson dishwasher but could not remove it. the floor tiles are right up to the kick board . it is bringing in water the heater and pump all seem to be working. so problum with washer pump. it is semi intergrated with brown control pannel knob on the right hand side selectes the washes. left hand side knob you put it to start it does the rinceing heating empying. would any one know the rating of the capactor on the washer pump on this dishwasher. will have to go back when the get the tiles removed. dont you just love kitchen fitters. fasetester 🙁
September 17, 2007 at 4:59 pm #227589fasetester
well guys no one know if i can get in from the front when i was testing the dishwasher after filling there was not even a hum from the washer pump usally if it was jammed or capactor fault you would here some thing i would like to sort it if possible as the have to lift the tiles to get the kick board off the sump inside is like a creda any other help thanks fasetester.
September 17, 2007 at 7:32 pm #227590Penguin45
Broken wiring in the door? You can get them from the front…….
September 18, 2007 at 2:36 pm #227591fasetester
thanks for the reply chris wil let you know the outcome 🙂 fasetester.
September 19, 2007 at 10:15 am #227592fasetester
went to dishwasher today even when i have all the screws out the dishwasher will not move. could not get it out. what could be holding it. hi chris me again. when the dishwasher starts a program it pump out then fills for about 20sec. then you can hear the water empying out even when it is switched off. at the wall it does not matter where you put it on the program wash rince ect when you kill the power at the wall and open it the water is empying out. when you pull out the drain pipe not that much water coming out it is not pumping like for over fill or running anti flood . possible that why washer pump is not going. any help please fasetester.
September 19, 2007 at 1:42 pm #227593Martin
But it is clearly an anti-flood problem from what you say fase. That baby’s got to come out for you to sort it mate… get back in there…..! 😉
September 19, 2007 at 1:55 pm #227594fasetester
thanks for your reply martin you would think it was siphon. the water is running out and not giving the washer pump time to wash. what would i need to check the pump is not running it is empying throught gravity .martin and how do i get the legs to ajust up thanks. fasetester 🙁
September 19, 2007 at 2:13 pm #227595Martin
fasetester wrote:martin and how do i get the legs to ajust up thanks. fasetester 🙁
Search me pal, I’ve no idea, not sure what an old jacksons legs looks like any way? I guess they are metal, need a load of WD40 to free off and possibly a 10mm spanner….?….dunno?
What I do know is that the base is most likely flooded, the anti-flood device is causing the drain pump to run continuosly and you need to unscrew those legs somehow? 😕 Even if the machine is BER at least you can drag it out and charge for doing that, otherwise their problem only gets worse I guess? 8)
September 19, 2007 at 2:23 pm #227596fasetester
martin the pump is not running as if you held the drain pipe down and the water flowed out then when it empys sump brings in the water valve is there any thing else other than the drain pipe siphoning would cause that thanks for your help fasetester 😕
September 19, 2007 at 10:39 pm #227597fasetester
hi guys is there any thing other than siphoning that would cause the water to trickle out of the sump would the iwms cause that it is not the anti flood the pump is not running it seem to be empying throught gravity thanks fasetester 🙂
