Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Jackson Lichfield Double Oven model 28111 – noisy Power Relay
- This topic has 4 replies, 4 voices, and was last updated 6 years, 1 month ago by
Oldrepairer.
February 14, 2020 at 11:34 am #97194
Oldrepairer
ParticipantThis is an old cooker, probably about 1990 but is still worth repairing if possible.
The power relay on the small PCB (EC133B , 13-670L) has suddenly started to emit quite a loud vibrating noise. This occurs whenever power is applied by the rotating controls to any of the heaters eg ovens or grill. As it appeared to be a problem common to power application, as a first possibility I replaced the power relay LZ 24S.
Sadly, still noisy.
I have the problem that I cannot get a circuit diagram or block schematic for such an old cooker so diagnosis is difficult.Has anybody thoughts on what could be the problem?February 14, 2020 at 11:48 am #466498kwatt
KeymasterThere’s more or less no info on it now, no wiring but you’d never have gotten the board schematics in any event.
February 17, 2020 at 5:00 pm #466499Oldrepairer
ParticipantOldrepairer wrote:This is an old cooker, probably about 1990 but is still worth repairing if possible.
Sadly, still noisy.
I have the problem that I cannot get a circuit diagram or block schematic for such an old cooker so diagnosis is difficult.Has anybody thoughts on what could be the problem?An update.
I managed to obtain a used PCB and replaced the original. Problem solved. Almost certainly the problem was a failing diode on the original PCB. When tested in the positive direction, it conducted for a split second and then went open circuit ( or very high resistance) I can only assume that this was happening repetitively causing the power relay to chatter. – good for another 30 years!March 26, 2024 at 12:56 am #466500scrapheap
ParticipantSame symptoms here though not being a repairer or electrician I don’t know if they result from the same cause.
Wondering if there are any repairers in the London area who can fix – many parts seem to be available for purchase new but I doubt, if it’s a pcb, that a new one can be found; might need scavenging one or having an electronics repairman fix the existing.March 26, 2024 at 10:13 am #466501electrofix
Moderatoryou could ask
https://www.qualityelectronicrepairs.co.uk/
dont know this board myself but it may be a simple fix if you can solder
would need to see s clear veiw of the board to see if i can guess which part is the most likely to failDave
