JL (Zanussi) T Dryer dead?
  • #91243
    JLTDC09…Pnc 91609633703.
    Mains up to main pcb but display is totally dead. I did check on the mains socket and found the polarity reversed but it has apparently been used on this socket for some time. Just in case I did try it in another good mains socket but no joy. I am assuming the pcb has died, unless you know better. 😉
    Re: JL (Zanussi) T Dryer dead?
    It sure sounds like it Jim. I bet it’s just a cap or resistor that’s given out on that board.
    #447532
    char14lew
    i think there’s reference to this problem in the pcb repair tips?
    #447533
    Would be grateful if you could point it out, just scrolled through the whole thread twice and couldn’t see any mention of Zan/Lux T/D pcb’ ?
    #447534
    Hollytree_Technical
    From Memory you need to change the SMPS chip (LNK304 I think) plus the fusible resistor and the bead inductor, if I remember correctly it uses basically the same power supply circuit as the Whirpool washing machine and tumble dryes but with a different value inductor and resistor.
    Jem
    #447535
    Could the fact that it was plugged into a socket that had reverse polarity have been likely to have caused the failure, if there had been a power surge for instance?
    #447536
    Hollytree_Technical
    The reverse polarity shouldn’t have made much difference although it may be possible.
    My personal experience is that this range of smps chip will run for 6 to 7 years and then fail for no obvious reason after which it blows the bead style inductor and then the fusible resistor blows to stop further damage.
    Jem
    #447537
    Thanks for that info, may be a little late in this instance as she said she wants a new dryer but worth knowing about for the future.
