Looking for advice, customer tells me lack of heat although the fan works and there is some heat, is there anyway the heat sensor can be checked. !! guess
also could be pcb.!!
cheers john
This is a multi-function oven so will it heat normally on conventional heat but not on fan heat? If so that rules out the sensor. My guess is that the fan element has blown, hopefully. Fault finding and diagnostics on this oven is far from simple. Have fun! 😀
