JLDWW1307 prod 91151923001
  • This topic has 1 reply, 2 voices, and was last updated 4 years ago by alro.
  • #100715
    alro
    hi gents no display on this one have 240v into bottom board pcb need tech if poss to help me out cheers alro
    #481878
    you need to check the low volt power supply on the lower board. On most lux board there are low ohm 3watt resistor acting both as fuses and current inrush arresters.
    have emailed some tech but had to use 2 emails because of size
