I have a john lewis oven jlbios602 which is equivalent to many others.
The oven does not cut out after reaching the correct temperature.
I have two ovens side by side so i have swapped the circuit board and the temperature probe from one to onther but still it over heats and doesnt cut off. I have to turn off at the mains to reset it.
The only thing left to try is the overheat stat but why would this stop the oven cutting out when its reached the correct temp? Its means stripping the case down to get at this so ive left until last.
The parts cataloge shoes a stir up stat but i cant see one in the oven. Im not sure what they do anyway!
Any ideas?
Jules.
