When using the main oven, after around 20 mins it shutdown, all lights go out and the timer.(clock) display..after about 10 to 15 mins it comes back on…but the cock has to be reset, they tell me when this happens the cooling fans still runs…there is a overheat stat listed but would the clock and all power to lights go out due to this stat..or maybe another issue. any advise please
John
Ahhh had to laugh when reading this “cock had to be reset”,
presume either the cut-in or out ‘stat for the cooling fan is at fault, there’s a t’o’c normally mounted behind main oven that normally does this, newer ones are on/off switching, earlier ones were one-shot I think.
