Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › JLWD 1408 (Zanussi Sigma?) Drying function kaput.
- This topic has 5 replies, 2 voices, and was last updated 12 years, 6 months ago by
Elsubstar.
October 15, 2013 at 9:29 am #77634
Elsubstar
ParticipantHi, I have owned a John Lewis Washer Dryer 1408 for a few years now, but for the last year the dryer has not worked. I found the error testing method –
http://www.ukwhitegoods.co.uk/help/fix- … codes.html
for Zanussi on this site which was helpful to a degree. While the panel testing took place, any light associated with the dryer flashed up orange instead of green as shown with the properly functioning washing programs. (Some pics attached.)
To carry out the test cycles I turned the program selection knob one click clockwise and the machine started to fill but then stopped and didnt do anything for 1/4 of an hour so i drained the machine thinking id try again later. During this process the LEDs on the right hand side in a vertical row were green apart from the ‘dryer’ option which was again orange.
Sorry this is a bit long winded, but if anyone could give me any clues to what i should do next would be great! Thanks in advance!
October 15, 2013 at 11:04 am #402841kwatt
KeymasterRe: JLWD 1408 (Zanussi Sigma?) Drying function kaput.
What’s the service number, PNC code on the rating plate?
Have you looked at the machine inside as a lot of things are fairly obvious in some, such as a reset thermostat?
October 15, 2013 at 11:25 am #402842Elsubstar
ParticipantRe: JLWD 1408 (Zanussi Sigma?) Drying function kaput.
Hi K. Thanks for your reply.
Ill look for the service number, PNC code on the rating plate when i get home tonight.
I haven’t seen anything obvious. When you say inside, where do you mean? I cant see anything in the manual about a thermostat rest either.
E.
October 15, 2013 at 5:59 pm #402843Elsubstar
Ok, so I have found out its Prod No is 91460311000, service number- 745 00017.. I have found the thermostat is a manual reset-
http://www.ransomspares.co.uk/parts/bra … 1460311000)/thermostat-man-reset/77598.htm
And I have located it in the top of the machine, but I don’t know how to reset it?October 15, 2013 at 6:19 pm #402844Elsubstar
I have tested the thermostat and current does run through it so started another error test once I’d put the machine back together but the same orange LEDs relating to drying functions flash up. Have clicked the program selection dial around another click to se if it completes the test cycle this time. Fingers crossed.
October 15, 2013 at 7:52 pm #402845Elsubstar
It got suck again 5 mins into the error test.Not sure where to go from here? Anybody’s help would be appriciated!
Thanks.
E. -
