JLWD1404 no drier heat
  • #61718
    simtoms
    This JLWD1404 works fine on wash and appears to work on dry but gives no heat. Elements fine, stats are good, thermistor seems good. Seems like a board fault although no external fault apparent. Was wondering if a dodgy pressure switch could cause it because power comes via it to drier system. Gives two clicks when puffed into. Anyone had this B4? Thanks, Simon 😕
    #347357
    Re: JLWD1404 no drier heat
    If it has the thermistor in the condenser to tub hose, above recirculation pump, check the wires to it are not broken.
    Mike.
    #347358
    simtoms
    Thanks Mike, havent checked that yet.
    Simon.
