JLWM 1604 problem
  • #86602
    KevinS955
    Machine is just over 5 years old…three months outside extended warranty period!
    PNC 914522631/02
    SN 029 000013
    Machine stops during washing cycle on all programs, usually after about 10 minutes but sometimes up to 25 minutes after start. Cycle just stops and spin speed indicator shows zero. no error codes shown, drain and spin functions work. rinse function malfunctions similarly to wash cycles, runs for about 25 minutes, then spin speed goes to zero and program stops. door lock and heater works. sounds like a processor problem. Any ideas what I should check?
    thanks
    Kevin
    #432321
    Re: JLWM 1604 problem
    If the heating element has an earth leak that can cause crazy things to happen to the electronics.
