JLWM1437 (Electrolux) Direct Driver Inverter W/M – Slow Spin Speed
Home Forums Public Support Forums Help And Support Washing Machine Help Forum JLWM1437 (Electrolux) Direct Driver Inverter W/M – Slow Spin Speed
  • #100582
    pearce_jj
    Hi, hoping for some help.
    Washer is working normally (quite and stable) except that the spin speed seems to be reduced to only 300rpm (top speed should be 1,600rpm).
    Drum feels smooth, turns literally silently. Pump cleaned. No errors displayed, it just reaches the lower speed and that’s it.
    I’m wondering if the inverter board might need replacing.
    #481289
    pearce_jj
    To add. The other thing that’s changed is that if a wash is paused, the door doesn’t unlock. Maybe there is a water level sensor that needs cleaning or replacing?
    #481290
    Are you putting a full load in?
    This problem can be caused by under/over loading the machine.
    #481291
    pearce_jj
    Thanks for reply. Same even when machine empty.
    #481292
    pearce_jj
    Also, I ran a 90* wash but it doesn’t appear to be heating the water at all.
    #481293
    check the heater
    if heater has gone it may be the total problem and odd earth faults on heaters can cause problems
    pearce_jj
    Thanks. Heater is 31 Ohms and the NTC sensor reads 6k at about 20*C.
    Ive been trying to get into diagnostic mode but so far without any luck.
    #481295
    pearce_jj
    For the benefit of the search. JLWM1437 service/diagnostic mode is the same as AEG 6000/7000/8000/9000. To access, turn off machine at wall. Set dial to Cotton. Turn on machine at wall. Turn on machine with on/off button if it hasn’t come on itself. Touch and hold “Start” and “Reduce Time” for about 3 seconds. Screen will display test (every segment lit). Then rotate dial to desired test program (see YouTube). Any errors will be shown. Power cycle machine twice to exit diagnostic mode.
    Last error can also be shown on-screen at any time by touching and holding the same buttons.
    In this case it’s showed E62 (overheating) and, on every test program, E71 (faulty NTC) – so I’ll give a new temperature sensor a go first.
    Error codes are documented here.
    Exploded parts diagram is available via Electrolux here, which gives part numbers for use elsewhere as well.
    #481296
    cant find values for ntc but it does not look too far out
    E71 fault is listed as short or open circuit ntc
    check the wiring before you jump in and buy one
    pearce_jj
    Thanks, will check!
    #481298
    pearce_jj
    [USER=”4209″]electrofix[/USER] – thanks, it was indeed wiring. One of the sensor cables was literally snapped at the point where the wires bend as the drum moves about.
    Cable spliced and machine is heating and spinning on the test programs, hopefully that’s sorted.
