Jockey Pulley Wheel Removal
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Jockey Pulley Wheel Removal
  • #21961
    bindidot
    I have a Proline TDV65 tumble dryer with a snapped drive belt. To replace the belt means removing the jockey pulley wheel from its arm. I can’t see how to remove the wheel without bending and possibly breaking the arm assembly and doing damage. Unfortunatly there are no screws that can be undone to do this. Does anyone know the procedure?
    Thanks.
    #193184
    Re: Jockey Pulley Wheel Removal
    bindidot wrote:To replace the belt means removing the jockey pulley wheel from its arm.
    Not correct. Belt passes around the motor pulley. The jockey pulley is tensioned against the outside of the belt by spring pressure. No disassembly is required.
    Power off at all times,
