Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › John Lewis Dryer
- This topic has 11 replies, 3 voices, and was last updated 14 years, 8 months ago by
hotpnt.
July 20, 2011 at 9:53 am #64033
hotpnt
ParticipantHi, not seen a JL one before, can anyone give some tips please???
this is what i had come through
We have a John Lewis JLDV02 tumble dryer which for some reason stopped mid cycle and the door was opened? It did show error code E40. The door will not close now. Is there something that needs resetting or is the door catch that is broken?
The door catch does line up but the toggle lock doesn’t stay toggled over to keep the door closed.
thanksJuly 20, 2011 at 11:48 am #355829Martin
ParticipantRe: John Lewis Dryer
Run that model number by us one more time, better still the PNC number.
July 20, 2011 at 12:03 pm #355830Criscold
Cause of errors under Code 40 – Door interlock faulty. Wiring faulty. Electronic board faulty. – let me have your email and I can send you some info
Colin
July 20, 2011 at 12:27 pm #355831hotpnt
Thanks, think its the door lock then, push/push type, any idea of part number please?
July 20, 2011 at 3:05 pm #355832Criscold
Part Number – 1254253253
Colin
July 20, 2011 at 8:15 pm #355833hotpnt
Thanks, much appreciated
August 1, 2011 at 5:14 pm #355834hotpnt
Can someone please tell me what an error code 60 is for also
August 1, 2011 at 6:30 pm #355835Criscold
Error Code 60 – Heater or board Fault
August 2, 2011 at 3:01 pm #355836hotpnt
thanks,can it be a stat problem then? is there a reset?
August 2, 2011 at 6:14 pm #355837Criscold
Don’t think a manual reset on this one. Reasons listed are
Wiring faulty. NTC sensor incorrectly calibrated/out of position. Power relay to heater unit faulty Heater unit faulty.
Intervention of auto-reset thermostat on the heater unit.Thermostat faulty (replace heater unit). Heater unit faulty.
Check Airflow
August 3, 2011 at 5:36 pm #355838hotpnt
thanks,is actually for a relative some distance away, the door catch broke, and now runs with heat for about 10 mins before error 60 comes up, so not sure what could be happening
August 3, 2011 at 5:46 pm #355839Criscold
Sounds like airflow – check filters, I had a job a few months ago where the heater was cutting out after about 5 mins and it was caused by the filter inside the door it looked ok but it was blocked with powder – washed it under the tap and as far as I know has worked OK since
