Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › John Lewis JLTDC03 start button turns red and bleeps
- This topic has 6 replies, 2 voices, and was last updated 3 years, 7 months ago by
beermontypython.
September 4, 2022 at 10:52 am #101140
beermontypython
ParticipantI have had this machine about 4 years and have been perfectly happy with it until today when after turning on and starting the cycle after 2/3 minutes the start button turns red but the machine continues to run, I have searched high and low but cant find the user guide. I am 78 years of age and dread the thought of having to buy a new one. I would be very grateful for any advise… Thank you
September 4, 2022 at 10:54 am #483504beermontypython
Participantbeermontypython wrote:I have had this machine about 4 years and have been perfectly happy with it until today when after turning on and starting the cycle after 2/3 minutes the start button turns red but the machine continues to run, I have searched high and low but cant find the user guide. I am 78 years of age and dread the thought of having to buy a new one. I would be very grateful for any advise… Thank you
I should mention that I clean the filter at the bottom regularly and have checked that it is clean, the door filter is also clean, the water tank is empty.
September 4, 2022 at 11:24 am #483505electrofix
Moderatordoes the button just turn red or is it flashing
if its flashing does it flash a sequence ie 2 flashes then a break then 2 flashes etc
September 5, 2022 at 4:14 pm #483506beermontypython
ParticipantHello Dave thanks for getting back to me. I gave the machine a good check last night after reading some comments on the internet, I started by unplugging the dryer from the power socket sometimes this has worked when having problems on other items. I then put a very wet tea towel in and started the machine. it tumble for about 20 minutes, the blue light didn’t come on, I turned the machine off, the tea towel was wet through and I couldn’t feel any heat inside the drum..
In desperation.I ordered a new heater and it arrives tomorrow I’m just hoping I can manage to fit it, if that doesn’t make any difference, I think I will hang myself,,, ONLY JOKING 🙂
,September 5, 2022 at 4:16 pm #483507beermontypython
Participant1 More question Dave, in the past when I have used this brilliant website, I always received notification when anyone replied but I haven’t had any notification, do I need to change something,,, THANK YOU AGAIN
September 5, 2022 at 7:09 pm #483508electrofix
Moderatorlook in the user settings and see how its set
September 7, 2022 at 3:50 pm #483509beermontypython
Participantelectrofix wrote:look in the user settings and see how its set
dave
than you dave,,all sorted
