Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › John Lewis JLTDC09
- This topic has 6 replies, 3 voices, and was last updated 10 years, 12 months ago by
hebegebe.
April 13, 2015 at 7:48 pm #84694
hebegebe
ParticipantWould really appreciate some ideas on this dryer (Prod No.916096337/09)
Fitted a new module to replace old one that was completely dead. New one powered up ok with display, but condenser light on and ERR appears in the display when start button pressed and nothing happens (Red led on Start button flashes).
Diagnostic cycle proved that everything works, motor, heater, pump but on one setting (Just about 5 o’clock on the dial) E32 appeared. Checked carbon brush connections and all appears to be ok. Surely not a faulty module. Any ideas what might be causing it? Is there a sensor for the condenser to cause the condenser light to come on?
Thoughts or a circuit diagram would be very much appreciated
Graham
April 13, 2015 at 8:10 pm #426497bazza500
ParticipantRe: John Lewis JLTDC09
Have you purchased the preprogrammed module?
April 13, 2015 at 8:26 pm #426498electrofix
ModeratorRe: John Lewis JLTDC09
configured part number 97391609 63 37-09 / 2
non configured part no 136 40 36-50 / 7
April 13, 2015 at 9:38 pm #426499hebegebe
Thanks for your reply Dave.
Have bought a configured module but part No. 97391609633702/7.
Any ideas if that number is suitable?
Graham
April 13, 2015 at 10:09 pm #426500hebegebe
I’ve bought the wrong module haven’t I!
Thanks for putting me right Dave. Maybe it’s time to retire before I give Connect all of my pension!
Just before I order another module, Prod No.916096337/02 has a microswitch to prove the condenser door is closed. This switch is omitted on Prod 916096337/09. With the help of a wiring diagram, maybe a simple link between two contacts on the board would provide the signal it is looking for. Can anyone help?
Graham
April 14, 2015 at 8:42 am #426501electrofix
info sent
April 16, 2015 at 9:27 am #426502hebegebe
All up and running now. I inserted a link into the plug on the board to tell it that the condenser door was closed and away it went.
Very grateful for your help Dave
Graham
