john lewis jltdc10
  • #94195
    dunston
    Hi we have a john lewis tumble dryer, model JLTDC10, PNC 91609633400 in for repair. its heating but not drying the clothes. the condenser is clear, pump is working and the rear fan is running. is there any other problems with these dryers or does anyone have a service manual PDF. Thanks Mark. ps. this dryer does not have an element. it uses a heat pump (compressor).
    #456681
    Re: john lewis jltdc10
    The fact it’s getting hot would mean the compressor is working. Will see if I can dig a manual up later
    These units are no more than a dehumidifier with a drum. The condenser ( or more like evaporator) should get cold to allow water to drop out of recirculating air. As long as filters are clear then there is no reason it should not work
    whitevanman
    cant pm you the manual hey ho.
