John Lewis JLWD1612
  • #95104
    robbo1973
    Hi all got a weird fault on a mates washer dryer,its in a small space so going back in a couple of days when its pulled out to check it but basically washer is fine but when set to dryer it starts the drum rotates and water inlet valve lets water in but after maybe 3-4 mins you hear the dryer board relays click a few times then it stops then starts again and repeats this 2 times then shuts down and door unlocks,no fault codes?
    #459414
    did you go into engineering mode to look for fault codes ?
    robbo1973
    i didnt , not sure how to on this model,is it listed in the known fault codes ? or is it something you could send me . planning on going back thurs fri
    #459416
    let me have your email and will send you all I can find
    Hollytree_Technical
    Its an Electrolux based machine so check the insulation resistance of the drying element and if it is around 3 meg or below then change it.
    #459418
    robbo1973
