john lewis jlwm1201
  • #64773
    adv
    this comin up with e 50 help lads any ideas machine wont do anything?
    #358029
    Criscold
    Re: john lewis jlwm1201
    E51 Motor power supply triac short-circuited PCB faulty; current leakage from motor or from wiring.
    E52 No signal from motor tachometric generator Motor faulty; wiring faulty; PCB faulty
    E53 Motor triac sensing circuit faulty PCB faulty
    E54 Motor relay contacts sticking PCB faulty; current leakage from motor or from wiring
    You need to enter diagnostics to find the correct error code
    Colin
    #358030
    had done the same info criscold beat me to it
    check for motor shorts to earth that can cause E51 faults
    check obvious like brushes
    if motor turns and stops check for tacho output
    adv
    when i held reset an another button all lights flash up and down as i moved timer knob round e51 came up is that the pcb duff en? ta
    #358032
    same fault code comes up if motor has an earth fault
    ie wet or carbon dust
    adv
    cheers lads
