John Lewis JLWM1202 dead!
  • #53523
    Just died yesterday in fact………………Before we commit his body to the land fill can I just ask maybe he is just sleeping and worth waking at least? 😕
    On his body it is marked JLWM1202 and only the door lock neon shows any sign of life. Now I’ve whipped out his heart and had a look at the PCB and there’s no sign of any cardiac problems there. His arteries seem intact and plugged in nicely, his front panel seems just as healthy looking.
    What I’m not too sure about is his knob? Now again a closer inspection reveals all arteries connected to it are OK but I have to admit that is where I suspect the problem may lie? But I could be wrong, however I have based my assumption on the fact that only two devices can affect the electronics being so very dead as they do. The door interlock does get a bashing as does the knob. Furthermore I’ve fitted a new interlock and still nothing!
    Can anyone give a second opinion on that patient? Or arrange a funeral service?
    #316306
    gandh1
    Re: John Lewis is dead!8O
    am i the only one to smirk at the frequent misdirectional use of “knob” ?
    being a zanussi board you should be able to get into doagnostics to at least try and illuminate all the leds/eyes/other ancillery bodypart term
    #316307
    Behind the knob is a 24P (positions?) programme selector. Seems to be obsolete. Seems there’s little to lose by trying to pull it apart and fiddle with it 😯 .
    Mike.
    PS: Did you take the old lock apart to see if it had shorted internally? If it had, I’d follow the wires back to the board and look very closely for a triac with a hole in it, for example, or smoke signs on the plastic module cover.
    #316308
    gandh1 wrote:being a zanussi board you should be able to get into doagnostics to at least try and illuminate all the leds/eyes/other ancillery bodypart term
    The machine is dead! Therefore no lights, diagnostic access impossible.
    leavemetogetonwithit wrote:Behind the knob is a 24P (positions?) programme selector. Seems to be obsolete.
    Just to cover myself I’ve ordered a new rotatary switch (3794404008) from Masterpart. At just £13 I thought it worth a shot?
    leavemetogetonwithit wrote:PS: Did you take the old lock apart to see if it had shorted internally? If it had, I’d follow the wires back to the board and look very closely for a triac with a hole in it, for example, or smoke signs on the plastic module cover.
    No Mike, I don’t want to mess around taking interlocks apart TBH. As I said earlier, I have inspected both sides of the main board (using a magnifying glass) and there’s no sign of damage, no popped triacs or surface resistors..nothing. If the interlock had gone faulty and shorted internally it would have blown the module big time and I’d have spotted that I reckon.
    So by way of a calculated gamble I resting my hope on the selector switch but left wondering all the while if anyone else has come across the same (or similar?) problem on this style of Zanussi/Lux/John Lewis with the big central ‘knob’? 🙂
    #316309
    gandh1
    just thought eh and realised the door lock neon on the door one did mean, ooops sorry
    #316310
    A couple of threads you might find of interest,
    Madmac
    me
    Mike.
    #316311
    bigchrisoioi
    will be intelock and pcbs, probely main and display…….i work for serviceforce and get this all the time esp after power cuts….
    make sure the pumps have resistance of about 180ohm’s and not below 10ohms..
    hope this helps
    #316312
    gandh1
    martin, just had an odd one today, tricity aw1000 with no power…
    turned out to be a break in the neutral at the entry point to the rear carcass where that silly black plastic thing crimps it up… worth a check i guess???
    #316313
    Well there is 240v to and from the mains filter and it goes direct to the selector switch. However I did’nt check at the selector switch but just ordered a new one. Customer on holiday for 3 weeks in New Zealand right now but will report back….Cheers guys. 😀
    #316314
    Martin wrote: Customer on holiday for 3 weeks in New Zealand right now but will report back…
    And?????
