John Lewis JLWM1203 Inlet Valve
Home Forums Public Support Forums Help And Support Washing Machine Help Forum John Lewis JLWM1203 Inlet Valve
  • #91877
    Rbz5416
    The inlet valve is letting water when the machine is idle. Getting access to the machine is a royal pain so can anyone advise what the part number for the replacement valve is?
    Is the valve serviceable in the case of not shutting off fully or is it a definite replacement. If the latter & dependent on cost I may just replace the machine.
    Edit
    Should have Googled first. I just assumed that JL wouldn’t be listed as a manufacturer. Seems to be part no. 50297055001 which is anything up to £50. 😥
    So if the valve can’t be serviced I think I’ll bin the machine.
    #449589
    don
    Re: John Lewis JLWM1203 Inlet Valve
    There is more than one valve for that model. Can you post up the PNC or Prod no. usually found on the inside the door.
    If valves fail replacement is the best way.
    Don
    #449590
    Rbz5416
    Thanks Don.
    Prod: 914522514 then 00 is separate box.
    Type: HI952431
    #449591
    valve part number 379 22 62-10 / 1
    https://shop.ukwhitegoods.co.uk/3792262 … fill-valve
    Rbz5416
    Thanks Dave. Just need to decide whether to repair or replace as I’ve never really been happy with the JL.
    #449593
    they are actually quiet good machines as they are built by Zanussi
    Rbz5416
    It functions well enough apart from a noisy bearing but the two things that have always annoyed me are the physical size & the alarm. The depth of the machine means it sticks out well beyond the kitchen worktop & is further space hungry with a bowed front & a protruding door.
    I know the alarm can be switched off but it’s very useful to prevent excessive creasing when you’ve forgotten a cycle is due to end. But I only need it to sound once, not every 10 seconds!
    #449595
    noizy bearing can be repaired but its a big job as the whole tub has to be removed
    sticking out. well this is getting more normal, as customers want bigger loads, and to get the drum bigger, they can only increase depth
    Rbz5416
    Part ordered for now while I give it some more thought. But at least I can do that without worrying about the valve failing completely & flooding the place…
    Thanks for the help guys.
    #449597
    Rbz5416
    A belated update. It was actually the valve itself that was letting water in the closed position. So can anyone make use of the two solenoids that came off the old one?
    I suppose it would make sense to keep one just in case but two seems overkill. As far as I can see the solenoids are identical, just different colours, is that correct?
