This machine appears to work fine with no load.When loaded will not revolve on wash,may revolve initialy on spin,then gives up.
Havent removed brushes,but looks ok.Could this be a load sensor fault i.e, pcb?
Re: John Lewis JLWM1203 Washing machine No Spin/wash
theres a possibility of the motor being heavily carboned causing a weak field to be generated as the insulation between armature segments is being greatly reduced by the conductive carbon dust.If the motor turns empty I would say its far more likely to be a motor fault than a PCB fault.
