John Lewis TD not pumping
  • #92558
    pmb
    Hi guys I have problems with a JLTDH19 prod 91609742400 which is not drying. When I check the pump area it is full of water and no blockages (I have cleaned it previously). When I start a cycle it drains straight away without any problems so I suspect the pump could be cutting out but I wanted to check for fault codes, does anyone have a service manual they could send me please? And do the pumps fail on these?
    Thanks, Darren
    #451576
    Re: John Lewis TD not pumping
    Does the program not complete at any point? During that time does the water container actually fill with condensate water? To access diagnostics (see attached photos from manual)
    #451577
    pmb
    Thanks a lot Martin, I will find out some answers when I go back
