The washer is fine, but have lost the negitive feed to dryer side , no fan/heater/ but have positive feed. On inspection found the T/D fan tight possibly has put stress on the small motor, would this damage the main Pcb !! and cause this type of fault. (expensive part)
Thanks John
Neutral for elements goes via cut out fitted to tunnel ( 2 fitted one live and one neutral) and then via contact 22 on pressure switch.
Could be main pcb if fan is not running as well
Hve emailed you wiring diagram so you can check module, contacts etc
If its a Zanussi in a skirt have you checked the condensor water valve? Will not switch neutral to heater until it has detected water through condensor and then will not switch fan on until it detects heat from dryer element.
