Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › John Lewis Washer Dryer 1612
- This topic has 12 replies, 3 voices, and was last updated 8 years, 11 months ago by
Paul81.
April 17, 2017 at 7:19 pm #91056
Paul81
ParticipantI just bought on auction John Lewis washer dryer 1612. It was working fine first time when I tried to use it next time it came up with error “1” – no letters in the front. Can anyone help me, what is the problem with it? I tried to have a look what is wrong with it and only think which sometimes help is when I shot doors an it click twice than sometimes it works (not always).
Thank you for any help.
April 17, 2017 at 11:27 pm #446881electrofix
ModeratorRe: John Lewis Washer Dryer 1612
post the full model number and pnc number if it has one
April 19, 2017 at 8:56 am #446882Paul81
ParticipantRe: John Lewis Washer Dryer 1612
Product number is 914604700/01
April 19, 2017 at 10:40 am #446883captaincaveman1
This model doe’s not have an error 1 however what can happen on this model is the door lock can stick with one minute to go so I would be looking at a replacement door switch
April 19, 2017 at 12:22 pm #446884Paul81
I all ready replace door lock. It looks like it is stick on 1 minute. The oddest think is whichever option I choose and pres start it is showing 1 minute straight a way and machine is pumping out the water. Is there anything else I can do or check?
April 19, 2017 at 1:38 pm #446885electrofix
does sound like an ood fault.
all fault codes on display machine come up as E followed by a number. the closest to 1 is the E10 series which is all about filling faults. in your case it seems to be only allowing you 1 minute programmes
is it running some sort of programme and only taking 1 minute or is it not starting at all
April 19, 2017 at 2:04 pm #446886Paul81
It shows 1 and then starting to pump out the water. But after pumping water out it is stuck and do nothing (display 1 all the time). I need to open the doors by puling emergency opening think.
If I live it alone for about a week it will work totally fine but just once and then if I try to use it again it will straight go to 1.April 19, 2017 at 2:34 pm #446887electrofix
is there no flashing lights anywhere ?
think the first thing to try is a long shot. unplug and take the top off and remove each connector in turn and replace it on the timer. Bad joints can sometimes cause problemsalso some fault codes are not shown to the user and the machine has to be put into engineering mode. I can only give that information to a qualified engineer but it may be available on google and utube etcetera. if you get the fault code we can take it from there
April 19, 2017 at 2:39 pm #446888Paul81
only light above start button is flashing red but I don’t remember is it all the time or not. I will have a look later.
Thank you Dave, I will try to check that fault code once I’m at home.
April 19, 2017 at 3:22 pm #446889electrofix
if its flashing see if its flashing a sequence ie 6 flashes then stop then 6 flashes then stop and repeat
if yes that’s a fault code, let me knowDave
April 20, 2017 at 6:41 am #446890Paul81
Light is on all the time.
I managed to get it to service mode, when I get to position C10 I get message EHE, the same was for C11,C12, C13, C14, C15 and C16. When I switch it off and on it displayed ELE I couldn’t do anything so I switch it off and on and it went to service mode again. This time EHE appear just at C5 and C6.
After that I switch it off and on again and it worked fine once. after that it was going in to the same problem as previously – displaying one.I checked all cables and connections everything looks fine nothing loose. Is it possible it is something wrong with the main board even if it sometimes works without any problems?
April 20, 2017 at 8:30 am #446891electrofix
well can see now and it may not be good news
EHE fault reads
Inconsistency between FCV relay (in the main board) and safety “sensing” circuitpossible causes are
Faulty wiring; Main circuit board faulty.fault description is typical lux leaving you going “you what” . Causes of fault listed are not always complete. In practice there can be other causes that bring up various fault codes that are not listed. What I am saying in a round about way is I cannot guarantee if you check wiring and change board it will cure it
April 20, 2017 at 9:39 am #446892Paul81
Thank you very much for your help Dave.
