John Lewis Washer dryer issue
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries John Lewis Washer dryer issue
  • #101810
    lyndy
    John Lewis washer dryer JLWD1612, PNC 91460470001
    Fault code E10 on drying side.
    Washing side runs fine, dry side runs for about 10 mins then error code shows.
    Inlet valve, elements and TOCs all checked.
    Any ideas?
    #486255
    Hollytree_Technical
    I suspect that the dryer inlet valve is going open circuit after running for a few minutes, try checking it immediatly after the machine fails and it will probably show open circuit, I have seen several do this.
    Jem
    #486256
    lyndy
    Thanks Jem,
    Will check this and see if that’s the issue.
