John Lewis WM1411 (Zanussi 914531500)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries John Lewis WM1411 (Zanussi 914531500)
  • #88349
    jontymox
    Re: above washing machine display dead.
    I deduced that the display module was faulty, and renewed it as the machine would not switch on.
    Using my non contact voltage tester, I found that power was getting to the display module, and that the two wiring multi plugs are fine, so reckoned on a faulty display module.
    However, having renewed the above module, the m/c will still not power up!
    So, do I now expect a faulty main control module?
    jonty
    #437748
    Re: John Lewis WM1411 (Zanussi 914531500)
    it does sound likely
    was machine completely dead ie is it a board power supply fault ?
    SL
    The fault is the power pcb at the back or a low insulation on the wash element.
