JohnLewis Tumbler dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum JohnLewis Tumbler dryer
  • #95840
    PaulMG
    I have a JLDV02 S/No 64895796 which I understand is an Electrolux model. Is it possible to re-program the buzzer alert at the end of the cycle to a less annoying amount of times. Thanks.
    #461496
    Can you give us the product or PNC number from the rating plate? This type of information is always in the user manual if there actually is such an option.
    #461497
    PaulMG
    Re irritating buzzer. PNC 916 093 831 02. Type P541246. Hope that helps. Thanks.
    #461498
    Having read through the user manual there does not appear to be any way to modify the buzzer operation. 🙁
    #461499
    PaulMG
    Ok thanks, I’ll probably disconnect the wiring.
    #461500
    Well as you actually have to be in the vicinity of the dryer to hear the buzzer you could always just switch it off.;) As the same buzzer is used to warn of any faults it may not be wise to disconnect it.
    #461501
    the manual I looked at shows an alarm off button on the front panel
    has not yours got this button ?
    From my reading of the manual that button is just to turn off the alarm once it is activated, not to disable it Dave.
    #461503
    could be read either way they don’t make it clear
