Re: Kelvinator Deville 1985 model function switches
what is it tripping ?
rcd ? switch in your electric box with test button. if it trips this you have an earth fault. it may be you have connected an earth wireto the wrong place or you may have a faulty element as well. disconnect the elements and make wires safe. switch on and try all the switches and see if it trips
mcb this is a device to detect over current ie a fuse. if this blows you have a wiring error and you need a diagram or proffesssional help
