Kendall’s F +P washer
Viewing 1 post (of 1 total)
  • #47072
    kendall wrote:Could u please help me, I have a Fisher and Paykel washing machine. I have done the diagnostic mode test as u stated in one of your forums and the lights that have come up from left to right are off, off, on, off, on, off, on, on
    I think it may have something to do with the balance but am unsure how to fix this… any suggestions would be greatly appreciated.
    Thanks 😀
    You’ve got it backwards – it’s fault 43 – out of balance fault. Remove plug and two screws at back of top deck; lift away. OOB switch assembly is the pendulum hanging down. The switch and wiring at the top are very prone to getting wet, corroded wiring and switch failure. Also check that there is a small bias spring attached to the tub, pulling it forwards. If it’s off, the tub will hit the lever on a nuisance basis.
    Model number will be needed if you want part numbers for replacement components.
