Kenwood KSBSX17 American fridge freezer with ice maker in freezer door. Water coming through the dispenser fine, but no ice. No water coming into ice maker. Any ideas? Ice maker been replaced already.
Yeah, I get that, but there is no water entering the ice tray. Would the not getting to temperature affect water getting into the tray? I don’t think it’s a problem with the solenoids behind the ice maker, water is still being dispensed. I’m thinking perhaps there’s a break in the wiring somewhere inside the freezer door as is common with Kenwoods. Does that make sense?
If it’s getting down to temp then the valve, if the water supply works, is the next obvious thing to check as it’s usually a dual valve, one for water supply an one for ice. Easily checked for continuity with a meter to see if that’s okay.
zadokkodaz wrote:Thanks for the help guys. The ice maker was recently replaced for the same fault, by an engineer.
In that case i would call the tech company out and say its still not working, if you start working on it and then call them they will only say they cant do anything now as youve worked on it.
