Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Kenwood CK446 range oven and grill faults
- This topic has 9 replies, 3 voices, and was last updated 8 years, 3 months ago by
pc18.
January 2, 2018 at 3:51 pm #92959
pc18
ParticipantHi there, i joined up to look for info in the past for a previous issue with but ive now got another fault on my cooker.
The faults are on the small conventional oven and grill.
The small grill will still get hot but it will either trip the electric after so long in use or when we turn the grill off.
So i took a look at the switch and cleaned it up and the electric would no longer trip when turning the grill off but will every time the grill is used after a length of time.Other fault
Also since i had a look at the switch and put the cooker back together the conventional small oven will no longer heat up at all.
I thought i maybe got the wiring wrong on the selector pins but i have checked against a wiring diagram i managed to find which im pretty sure is for this type of cooker and it looks correct.The conventional oven i believe uses the top duel element and also one in the base. It looks to me like the top inner element is used for the grill and the outside part of it is used for the oven function.
I thought i would replace the switch which looks like this
however when i recevied the switch it looks the same as this one
https://shop.ukwhitegoods.co.uk/cs161-de-longhi-cooker-oven-selector-switch
So both switches look completely different and they seem to have different pin numbering so i am unsure if i can actually use this new replacement part on my cooker.
Has anyone got any ideas?
Happy new year!!
January 2, 2018 at 4:10 pm #452712don
ModeratorRe: Kenwood CK446 range oven and grill faults
Where did you order the new selector switch from?
Checked for your model number in our shop and the correct one is this one.
DonJanuary 2, 2018 at 5:05 pm #452713pc18
ParticipantRe: Kenwood CK446 range oven and grill faults
Thanks for the quick reply Don. I originally bought one from an online shop a long time ago but when i took the cooker to bits i realised it was the wrong part but i had the part that long i couldnt remember where i ordered it from so i then ordered a second one from ebay as i wanted it fixed for christams dinner and i seem to have been sent the same one again which is not the one listed or shown in the picture.
If the switch you have linked me to looks the same as the picture i will order that one, thanks
Hopefully that will help with these faults.
January 8, 2018 at 4:43 pm #452714pc18
don wrote:Hi
DonHi Don,
my switch finally arrived today and i have received the wrong switch to what i ordered.
The one i ordered is the one you linked me to but i have recived this one
my order number is 100139100
January 8, 2018 at 4:52 pm #452715electrofix
you will have to contact shop directly as mods on this site have no access to sales records
January 8, 2018 at 4:55 pm #452716pc18
ParticipantJanuary 8, 2018 at 4:59 pm #452717electrofix
its either compatible and it will fit
or its a picking error
either way you need to contact the store as mistakes do happen we are all human
January 8, 2018 at 5:04 pm #452718pc18
Ive sent a message through the site hopefully someone will pick it up.
The pin out looks completely different. And there’s no diagram or anything with it.
January 8, 2018 at 6:01 pm #452719electrofix
someone will get back to you
Are you sure you actually ordered the correct switch ? using the link Don gave you
https://shop.ukwhitegoods.co.uk/0500401 … tor-switch
January 8, 2018 at 6:18 pm #452720pc18
Yeah that’s the one i ordered Dave.
