Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Kenwood CKB200
- This topic has 7 replies, 3 voices, and was last updated 11 years, 4 months ago by
MDD.
November 13, 2014 at 7:45 pm #83019
MDD
ParticipantHi all, I am a retired electrician & have a problem with my oven, Occasionally whilst being used it loses all power even to the display board, After 5 to 10 minutes the power comes back on & the display board flashes till I reset it & continue to use it as normal, I am wandering if this could be the safety cut out & if it is where is it located, Thank,s in anticipation, Mike.
November 13, 2014 at 9:28 pm #421474Allsorts
ParticipantRe: Kenwood CKB200
Check the feed at source, the terminal block, the cable… If none of those, it is likely a failing capacitor on the timer
November 14, 2014 at 12:51 pm #421475MDD
Thank,s for reply, I have checked the supply, Is the timer part of the digital display unit?, Why do you not think it could be the safety stat ?. Regards Mike
November 14, 2014 at 3:02 pm #421476lee8
Probably a safety stat usually located on top or rear of cavity. The stats are a reaction/indication of but they are not the likely fault, likely the thermostat is causing over heat, fan motor, ventilation or cooling fan failure.
November 15, 2014 at 11:54 am #421477MDD
Thank,s for reply, I will monitor it for the time being & see if it goes off completely so I can trace fault. At the moment it has only happened twice in 3 months & by the time I would be able to get into the oven to test it it would have reset, The temperature thermostat seems to be working as the temperature indicator light is going on & off as normal when oven is maintaining set temperature. Regards Mike.
November 16, 2014 at 5:30 pm #421478MDD
I have ordered a safety thermostat & I am going to change this & check the operation of the cooling fan also clean the fan ducting. Has anyone any idea where the safety stat is mounted on this oven, Regards Mike.
November 22, 2014 at 7:53 pm #421479MDD
Hi, I have replaced the oven safety stat, It was located on rear wall of oven to the left hand side, To get to it I removed the top & rear covers & this exposes about anything one would need to replace in the oven,
Whilst I was in I tested the lower element as I had doubts if it was working & found it was open circiut, So have ordered a replacement. Only time will tell if changing the safety stat has cured my initial problem, but if it happens again I will try changing the oven stat. Regards Mike.November 30, 2014 at 6:55 pm #421480MDD
Hi All, I have replaced the bottom element & did not find it easy as old element was so distorted it broke up while I was pulling it out & I had to make a hook out of an old wire coathanger to pull all the bits out, Even this was not easy as the element slides into a narrow drawer under oven floor which makes it difficult to see what you are doing. Anyway its done now!, Regards Mike
